fordguy67
Active member
So after some long thought, and plenty of advise from all the you guys here THANKS, about my previous problem with the blue smoke (rings) and the dry valve train (???) I have decided to pull the motor and do a mild rebuild.
Not anything too extensive just rings, seals, plugs, flush, port & polish on the head (if needed), and an adjustable rocker assembly. Gotta check the oil pump and pickup too while I'm at it so I am gonna pull the whole motor.
Here is my question: I found a re-ring kit that has options for the brands and just wanted to know if one brand is better than the other.
Here is what it comes with:
Cast Piston Ring Set - Perfect Circle or Hastings
Rod Bearing Set - Clevite/Mahle
Engine Gasket Set - Victor or Fel Pro
Anybody have anything good or bad to say about these?
