Well, finally finished the throttle cable linkage on my 5200. Here are some pics of what i did. I used a pretty thick piece of metal as no flex would be allowable, I tried bending the stock cable bracket all different ways and could never get it to work. What I show in the pictures below works perfectly.
I know the linkage isn't exactly perpendicular with the valve cover like i guess it should be, but i think putting it at an angle like that helps it to pull the carb all the way to WOT, tested it out and sure enough it works as planned, it was quite fun making it with a drill and hacksaw
