Hi!
I know some of this has already been covered, but from everything I read I still have a few questions about changing out a head gasket on an 200ci six. I gather that since the thickness of the old gaskets mic out thinner than the new replacements there will be a loss of compression. My question is as follows -
I have a head gasket leak and wish to replace the gasket. Since horsepower/etc is not an issue, will the loss of compression that results from useing the thicker replacement gasket be noticeable enough to cause a problem? I cant afford to modify the head in any way at the moment, and if the difference would be that drastic, I will just wait until I can afford either a new head or the modifications needed. I do know that the current head has never been removed from the vehicle and it is the original head gasket.
Thanks!!!
James
Thanks!!!
James
