barishiman
I went back to the machine shop today and finally got my head back. Here's what went down:
The machinest replaced 4 exhaust valves instead of the initial two. Reason was that the valves were bent. He explained to me that my rockers could be off (moving diagnolly instead of up and down) causing the valves to bend. I did notice some wear on my rocker arm shaft when I disassembled it for cleaning. Some of the rockers had to be forced off and on the shaft. He's quoting roughly $180 for a new shaft and rockers.
So, what do you guys think. I'm looking for a second opinion. Also, what other rocker assembly could I look at if replacement is necessary?
Thanks again!
Thanks again!
