Yep, that's what it's called. You 'mill' a head and 'deck' a block, but in reality, it's the same thing either way, removing surface material to ensure a truly flat gasket mating surface.barishiman":1b2s63mn said:I didn't get the head decked, but the machinest did say that he resurfaced the head incase of imperfections from the past (guessing that was milling the head?).
Generally speaking, resurfacing either a head or block is taken to mean a light, cleaning cut. While milling or decking is generally taken to mean a more aggressive cut intended to remove larger amounts of material either to reduce deck height on a block (hence decking), or reduce combustion chamber volume on a head. 8)
Sometimes, resurfacing may turn into milling or decking due to the amount of material necessary to be removed to 'clean up' the surface, or as a result of mutliple visits to the machine shop over the years.
And most likely guaranteed to fail.addo":1b2s63mn said:New lifters on old cam - no problem! Just break in like a new cam, with cam lube. Other way round is not so clever or predictable.
