The engine speed for torque peak on this specific engine is just fine: 1650rpm, with a fairly flat curve from 1200-2800. The concern is not to mess up the benefit the long inlet tract gives the engine (before the turbo reaches full boost) between 800 and 1400rpm, while still maximizing torque & power available in the 2400 to 4000rpm range. Obviously from 4000rpm on up the long upper intake runners probably hurt a stock 300' I6's ability to draw as much air as possible at high RPMs, but that's not where most 'working' 300s spend much time.
This truck has gears that should allow it to stay near the peak of the torque curve at almost any legal speed. Just want that curve to be as strong, flat, and wide as possible, assuming that will also have a beneficial effect on fuel efficiency. Third gear on the C6, with both overdrives engaged, will put that 1650rpm torque peak right @ 60mph. Having a very flat curve should mean that the RPM range at which the engine will get its best fuel efficiency is also a wider spread.
Realistically, most road vehicles start requiring much greater amounts of power [and, therefore, fuel] to maintain steady-state cruising on level ground, at about 55mph; this due to aerodynamic drag, rather than rolling resistance of the tires, taking over as the primary power drain. Our trucks & SUVs are, aerodynamically, typically much worse than average cars, so that crossover point may be quite a bit lower than 55mph! Again the benefit of a wider, flatter 'high' torque range come into play.
Look at all the Ford engines that have 'variable length' inlet tracts. The little 4.2L V6 has a very wide range of 'high' [yeah, it's a relative thing]torque availability, for a small "V" engine. A lot of that's due to the dual inlet tracts. [The new Audi V8 40-valve RS-6 gas engine has 3 separate intake tracts per cylinder & puts out 450hp, and the 419lb/ft. torque is availabe from 1950 to6700rpm, all from only 4.2 liters. Their V8 diesel has only 32valves, producing only 274hp with 481 lb/ft; that from 4.0 liters; wouldn't that kick a 4.0L Ranger down the road!]
Don't know if multiple intake tracts was ever tried with our 300" I6, but the physics are the same. For Ford Motor Co. to have developed an aluminum crossflow head for the 300'/4.9L, with dual intake tracts(one a little longer than our EFI engines' intakes & one about half as long) would have been relatively simple or at least "do-able", and the results could have been staggering, not to say "embarassing" to the 4.6LSOHC V8 afficianados. For an individual to develop a dual length intake system, and for a non-crossflow head, seems like a huge undertaking. That, and I still can't get a fix on whether it even matters or not on a turbo'd engine. Any suggestions on where to look for this info are definitely welcome. For now the Sawzall isn't plugged in! TIA
J.R.
