This is for a 1968 200ci engine.
I recently purchased a header from Mike at FSPP. I am having trouble aligning the header so all the openings for the bolts line up with the openings for the bolts on the engine. All the bolts seem to go in properly except for the bolt on the bottom closest to the firewall. I can't get the header lined up so all the bolt openings match. I am using the correct gasket from NAPA. Can I not align the bolt openings properly because the head has warped slightly? Can I use a dremel tool to widen the bolt opening on the header?
Thank you,
Justin
Thank you,
Justin
