header, choke tube
jamerson84
If I put a header on my 200 will there be any place to put the choke heater tube? If not is there any other way to heat the choke besides that? I'm running a 1100 on a stock 200 three speed.
Thanks for the help.
Buy about 3' of 1/4" copper tubing. Tightly wrap one end around the #4 primary near the flange about 4 to 5 times, then plumb it up to your choke and cut off any excess.
The tubing and header thing works in a warm climate, but it's damned annoying in regions that have freezing weather. The problem is, headers have no thermal mass, and as a result, the choke pulls off too quickly. And on short trips, the headers cool off too quickly, causing the choke to close again when the motor is really warm enough to not need it...
Try the tubing thing; if it works, great. If you can't get it to work right, an electric choke cap may be the answer.
Hey Jamers,
I put a Cliffy 6-1 headers on my '65 Mustang; and I had the same question. So file this under "great minds think alike" dept!!! :lol: Anyway, what I did was to buy copper tubing, 1/4 " OD I think, or whatever the same size as the original. I put the open end way down in the collector, between all of the header tubes. Then attached it to the carb with the ferrules and nut from the stock set up. It is basically follows one of the header tubes and then makes one turn vertical up to the carb and looped into the carb.
When I bought my 'Stang in North Carolina and drove it back home the choke did not operate, period :shock: . First thing I did was rebuild the carb. I found dirt and grime in the small passage that is cast in the carb pad. The previous owner had put a shorter tube to the choke and it must have sucked up road dirt and stuff. The crud blocking the passage was not sooty or anything that might have come back from backfires. So by putting the open end down into the collector it is being protected from the dust and dirt flying around the engine compartment (as best as it can :? ).
And this is also the biggest mass of metal that will stay warm the longest. I have noticed when the air temp is around 50-60 it cools the header and carb quickly but the carb doesn't need too much choke action at this temp. So the carb does run rich at re-start up. But play with the settings, you'll find a sweet spot.
Have fun.
What all is involved with the electric choke cap idea ?
Sounds interesting.
Thanks,
Russ
