Doing a port/polish on a '78 200ci head. I want to gasket match the exhaust ports, but I'm divided about which gasket I should match to.
For the time being, and due to budget limits, we're going to have to use the stock exhaust manifold. Eventually that's going to be upgraded - probably to CI's dual-out header. I don't want to match to a different gasket, then move to the header, and CI's "improved design" header gasket and find that the ports once again don't match the gasket as well as they can. I am not porting the head twice, either. So, I'm not sure what to do here. Could I use the CI header gasket with a manifold, and just cut out the 3/4 divider part of the gasket (I'm not putting in the port divider) and then just buy a new header-style gasket when I switch to a header? Or are the gaskets close enough to each other in sizing that if I port according to a manifold gasket, my worries in regards to later switching to a header/header gasket are not a problem?
I hope I'm not being too confusing here. If I am, I can try to explain it in a different way.
