While I"m not running the 1100 anymore, when I was I had some 'heat' issues (notice I didn't say soak). It was actually related to a clogged heater core, a poor conditioned radiator, and a shot T-stat. The car never overheated, but the poor coolant efficiency was an issue. Once I fixed all of that stuff, I never had a heat related carb issue again. I could let it idle for 30 minutes on a 95*+ day, turn it off and let it sit for 20 minutes and it would fire right back up.
I did however, remove the coolant lines from the carb spacer. It's been debated here before, but I don't think it helps carb heat issues as it is running hot coolant through it to the heater core. I always saw it as a cold weather solution instead of a hot weather solution.
The only reason I'm dubious of all these spacers and heat soak solutions is that members of my family owned 6 cylinder mustangs brand new in 1966-1969, and never had an issue that is what is described here. As a result, I always think the problem is elsewhere. Like I said, tuning up my cooling system cleared up my problems.
Also, since you say it is stalling when you put it into gear, I would also want to look at the carb and make sure your idle isn't set too low. Check the choke as well. it could be cooling off too fast or dropping shut.
