abcdefghii
A few weeks ago the 200 6 cylinder in our 67 Mustang started knocking, that engine is currently out and hoping to go through a rebuild. Unfortunately we found out that the cylinder head has a crack that cannot be repaired, picked up a 2nd engine, only to find that the head on that one is also cracked.
In the meantime and to get the car running we picked up a 3rd running 200 that we were told came out of a 66. While the engine is in the car and runs strongly, we are having an issue with the carb that came on our original 200. The intake manifold says "7C2 D78E 8090 AB" see picture.
Can anyone identify that intake? Is there an adapter available that I can use to mount my existing carb? The 3rd engine did come with a carb, but the linkages are all different to those in the 67 so I cannot use it.
So... there you have it, hoping for some help to get this up and running.
Edit: OK, found this https://www.vintageinlines.com/product-page/1v-carb-adaptor-small-1v-to-large-log which I believe will work for what I want.
Thank you.
Thank you.
