help with measurement
did i measure my intake pattern on my new head correct for a 2 barrel adaptor. i got 3' bolt to bolt and 13/4 hole size. i cant find an adapor that says 3' what should it be its a 1969 ford 250. I am buying a new holley 500cfm is that to much fuel for my motor. I am putting a
CSC-264-10-SHS 264/264 214/214 .450/.450 .480/.480 .495/.495 110* 1400-5000, from mike. right now i have a 350cfm but no aftermarket cam
Are you measuring the bolt holes across the head itself or across the OEM spacer that's bolted to the head? The bolt holes across the head should be either 2-3/4" or 3-5/8". A 1969 250 should have a 3-5/8" spread.
