All the 170's, 200's and 250's with C4's after about 1971 got a really good Allen bolted kickdown lever which is the best in the world. When you bolt on a 5200 or 32/36, you can't use the stock Pinto/Capri C4 or C3 kickdown raided from the donar car of the carb, as the carb is aways on the wrong side, and the kickdown rod for the post 1971 head has to move across the engine bay, and the C3 or C4 or C5 kicdown lever used from the later vehicles. The 5200 has the 1st and 2ndry barrel reversed, the electric, water or manual choke on the other side, and the actuation is opposite to the 32/36 and Weber 38. This means you have to figure out what way the carb has to be mounted to copy the rod or cable accelerator. Case 1 is the stock kickdown rod and rod accelerator, a very good set up. Case 2 is the Fox body rocker cover stirup mount, which is also good, but has a few limits on what direction you can mount the carb.
Since the earlier Fords use the rod operated carb linkage, and the kickdown lever runs off the accelerator rod, we need to use the type that suits.
When we put a 1978 Fox or Granada head on a pre 1971, then the carb actuation needs to copy the earlier Case 1, the earlier rod set up, and move the rod kickdown as per the 1962 to 1968 Ford i6's, OR adapt the stock Case 2 Fox cable and then rock the stock kickdown rod.
In Case 1, the carb needs to sit like this, or some position like it. It can be parallel with the head, or, if you able, 90 degrees to it, but the kickdown lever needs to run of the rod.Care of Mr Salazar, aka
bigredraza
The lever operated early round bodies hold the key
The 32/36 carb linkage and secondary position is
reversed when compared to the 5200 Holley Weber version. That allows the linkage to work when its arched over the log manifold. Albert Pennello used the 5200 Holley Weber, which is a handed 32/36 DGA Weber. His Clifford set up was like this,
http://www.albertpenello.com/mustang/throttlearm.jpg
Cliffords adaptor eliminates the 16 dgree slew, but the linkage with the 16 degree slew, and the reversed image 32/36 versions on the Weber,
allows the linkage to canterlever off the centre of the log like it was made to be.
Landons Stovebolt adaptor put the carb on a 16 degree pitch when used without the stock water heater intermediate part, and it then lost the pivot point.
http://home.centurytel.net/fordfan/Falc ... adap01.jpg
In Case 2, the 32/36 has to be placed with its two barrels at a 90 degree angle to the line of the head so the stock Fox accelerator cable pivots the throttle, and the kickdown lever can run off the stock linkage. The bolts on the head tend to make the adaptor sit on a 16 degree slew.
