john-dickjr
i am ordering new pistons for my motor , i want to be 100 percent sure that they will work before i spend $500.00+ on new pistons..i have a 300 crank and will use 240 rods, here is what i need a compression height of 1.215...close i can find for off the shelf pistons are ford 331 stroker pistons , which are 1.175 ch, only .040 difference which can be easily fixed with decking the motor a tad, with a 10.00 deck would be .038 in the hole, and still be near 11-1 depending on my head cc and head gasket i use, i found some probe and srs forged piston that have the .912 pin size,
