Inline6Merc
Go ahead and weld it since its not any good with a hole in the block. But before you begin to weld on the block get a junk cast iron head or something of the same material and practice welding on it first. When you weld cast iron, you want to pre heat the area your welding uniformily and no hotter then 1400 degrees feirnheit. When welding cast iron make sure to keep welds minimal. Also hit the weld with a peening hammer after welding. Once you have finished welding cover the area in insulation or burry it in sand. All of these steps are taken to minimze any stress/cracks that can occur when heating/welding cast iron.
-curtis
-curtis
