bronco6banger":38rr85ho said:
On doing some research I also found complete sections on enging block repair. What I got here is looking more and more like nothing. which is good because I am broke.
So just because some can only bolt things up, thats good for them. Keep on bolting up.
Also about a rod coming apart. The peices of metal that fall to the bottom and clog in the filter are no worse than the dust and dirt that makes it in the engine from crappy filters. For those who actually answered the question I had: thank you. For those who have $20.00 motors: I'll give ya $21.00 for one.
We all have to strike a balance between doing it right, and doing what we can. None of us has limitless resources.
This particular situation falls on the dumb side of doing what you can.
You have a motor that threw a rod through the side of the block. In order to get that motor a reliable runner again, you are going to need to AT A MINIMUM replace all the bearings, that particular piston and rod, as well as fix this hole in your block. You will also need to re-hone the cylinder that your are putting the new piston + rings into.
And that's if you get lucky and don't find any other damage (which I doubt, rods exiting the side of the block tend to do things like score cylinder walls and/or damage crank journals on the way).
So, Assuming your luckiest case, you need to find a "new" piston/rod. Now where do you suppose you are most likely to find that? In a 250 block. So why would you keep the current block ?
In the more likely case, you will open that motor up to find massive damage in addition to the normal wear and tear of years of operation - at which point the only way to get it back to running properly is a full rebuild. Once all the machine work costs in that are involved, even if you had to pay 100$ for a non broken block, it wouldnt increase the overall cost of the project by a very large percentage. At this point it is truely stupid to try and repair your block.
It's not a "city slickers" thing, or a rich/poor thing - it's just a common sense thing. You are going to have to dump X dollars to get a running engine. Why dump that money into a known damaged block when you have the option of dumping it into a good block? (I know you keep saying you can't find one, but seriously... I could go to the yard, pull you one and ship you the shortblock for less than 200$. Put a wanted ad in the classifieds and on craigslist and I bet you come up with one faster than you think.
And trust me, plenty of people giving you similar advice on this thread are WAY beyond the "bolt it on" modification crowd. Take a look around...
But.. if you are just trying to slap together some junk parts and you think that's gonna make a good enough motor for you - then you are on the right track. Might want to find the pieces of rod & weld that back together too. I hope you've got AAA.
