Batman1458
Active member
66 Mustang coupe (Sig has vehicle specs)
Anyone have any info on adjusting a Holley 1940 carb? The car starts fine and runs ok, but I think it may be idling a little fast. I have adjusted the timing, it was almost vertical on the block, after installing Petronix II, I tuned it down to about 10 degrees. The book says to adjust it to 6 degrees, but I find a little advanced works better in these cars. My 66 vert runs best about 14-15 instead of the 12 that is mentioned in the manual.
I am probably going to retard the timing a little more before messing with the carb, but wanted to get some advanced advice on the adjustments for this carb. I live in NJ and the average temp right now has been between 25 and 35 degrees F.
Thanks for the help.
Ed
Ed
