For you owners with a holley 2300 carburetor-350 cfm-500cfm carburetors.
Summit has the quick change jet kits bowls hly-34-25 for the 350 cfm carbs. this bowl is the gold color bowl.
For you with a 500 cfm carb which comes in shiny color, your only choice is the chrome quick change bowl hly-34-509.
also available is the fuel bowl see thru sight plug with o'ring seal hly-26-113. these kits from holley come with metering block gaskets & the special screwdriver for the jet removel.
Enclosed are the pictures of the 350 gold carb bowl with the jet screwdriver. not shown is the 500 cfm chrome bowl-with the same configuration. :idea: hope this helps william
