Finally got my cars overheating problems fixed by boiling out the system with muriatic acid
But after a extended cruise night tonite I ran into another problem... :x
After I've been cruising for awhile, (2-3 hours) the car starts to have a major hesitating problem and seems to be loading up. Once you get it out of town and can clear it out its fine again.
Problem is the carb bowl hanging out over the headers. A thermometer reading shows that the bowl is right around 170+ degrees and is too hot to touch on the bottom of it.
After you shut it off there is vapor coming out of the bowl vent and it seems to be boiling the fuel right out of the accelerator pump after it sat shut off for awhile because you have to pump it a few times after its running or you will get a major bog the 1st 3 or 4 times you give it gas.
Obviously I need some cool air ducting to the carb or a heat shield or both. I tried to make a shield a while back out of some aluminum stock but it seemed to make the problem even worse!
Should I make a sandwich out of some aluminum sheet and some really thick gasket material I have and glue it all together with my 3M panel bonding adhesive. You can hold a lighter up to it and it wont burn so it should work I would think?
BTW, Everything else is fine, not running lean or anything like that and my headers are jet hot coated allready and I am allready running cold air to the air cleaner and the hood scoop is functional too. Think that about covers it.
Thanks,
Doug
Thanks,
Doug
