Just thought I'd share some notes with everyone considering the Weber DGV carburetor (aka 32/36). Most of these notes are personal observations as well as information I've found through technical research of the carburetor itself.
The Holley/Weber 32/36 carburetor is a great carburetor but can be a little tricky to set up correctly with a 6 cylinder engine. For those of you who don't know, the 32/36 was originally designed for a 4 cylinder engine. This is not to say that is will hinder any potential performance or fuel economy when used in conjuction with your inline 6 cylinder engines. Only a few changes or rather adjustments will more than likely need to be made for your particular application.
Jets. With a few minor changes to the stock jets, this carburetor will give you the performance, as well as fuel economy, that most others cannot deliver. Notice I said stock jet sizes. More often then not, rebuilt Webers don't necessarily have stock jets installed in them during the rebuild. So, before you purchase any replacement jets, it's best to see what you have to determine what needs to be replaced. Each jet is stamped with the number on top or on the side of the jet themselves. They are a little difficult to see but a magnifying glass can rectify this problem.
Here is a list of jets and their associated technical names that should help you in determining the right set-up for your engine.
4 cylinder
Primary Main Jet 140
Secondary Main Jet 140
Primary Air Corrector Jet 170
Secondary Air Corrector Jet 160
Primary Idle Jet 060
Secondary Idle Jet 050
Pump Jet 050
6 cylinder
Primary Main Jet 160
Secondary Main Jet 160
Primary Air Corrector Jet 190
Secondary Air Corrector Jet 180
Primary Idle Jet 075
Secondary Idle Jet 065
Pump Jet 060
The first list is comprised of the stock jet sizes as originally intended by the manufacturer. Remember, these numbers are based typically on a stock 4 cylinder engine displacing no more than 151 cubic inches.
The second list was developed from a group of off road enthusiates, namely individuals from the Jeep crowd. Typically their engines are 6 cylinders with displacements of 232 cubic inches or more.
I have found the latter jet sizes to work very well(save one size small on the air jets 185 & 175 vs. 190 & 180) with my inline 200.
Lastly, I would like to emphasis the need to make adjustments with your jets in order to determine the correct ones for you. Typically, with more engine modifications, larger jets will be needed.
Hope someone can benefit from this information. You have any questions regarding the tuning proceedures, I have a copy of the manufacturers proceedures.
-Chris
4 cylinder
Pump Jet 050
6 cylinder
Pump Jet 060
-Chris
