Okay, I've fielded this for all your benefit. It's sort of like the Virtual Reality Drag strip with a bit more gutts to it. http://fordsix.com/forum/viewtopic.php?t=6711
RemeMber this?
Well, here is how to get the numbers. This system is very accurate to +/- 10% from my calculations, and is resonably easy to work through.
Here goes
9 things influence this 'k-value' above:
Intake manifold efficiency (ranges from 5%, 10%, 15%, 20%, 25% in most cases, with a rating of 1 for the best, to 5 for the worst). Pick the best choice form a rating 1 to 5 which replicates your intake. Most early 1.5" logs with 1" plugs will be rated at 5, while the later 1.75" hole logs with bigger welch plugs would be 4. A 250 2V is about 3, as is the 188 ME or 221 SP. An Offy 300 intake of any type should rate at 3. An independent runner EFI is about 2 for a stock 250 one, or 3 for an EFI 300. The Hillborne-type or Weber intakes are state of the art, rating at 1.
Degree of Carburation (ranges from about 15 cubic inches of engine to 1 square of carby venuri area to 44 to 70 to 98 to 125 for most carbs. A stock 300 I6 is about 125, rating at 5. A full on Triple Webered 250 can go down to 15, a rating of 1. Pick the best choice form a rating 1 to 5.
Camshaft Intensity (1= ~340+ degrees at lash, 2=~313, 3=~286, 4=~259, 5=~232). Pick the best choice form a rating 1 to 5.
Head Flow Subjective. 1= state of the art, 2=an aftermarket or reworked stock, 3= for a high-output, 4= most production head(s) for a stock lo-power version, 5=lousy. Pick the best choice form a rating 1 to 5.
ExhastSubjective. For branched controlled vortex with a primary size in excess of 0.8 times the intake valve is a 1. A standard aftermarket tubing header is a 2. A longer cast header with dual outlets can be 2 to 3 depending on the smoothness of the branching. A cast header with an outlet of in excess of the valve size is 4. A cast, undersized, sharp bended header is 5.
Examples of 1's are custom headers, 2 is an over the counter header, 3 is a great cast header, 4 is a ho-hum stocker, 5 is a nasty 1960 item.
Valve train configuration 1= Formula 1, 2 = DOHC 4V or State of the art Polyspheric or Hemi 2 valve, 3 = OHV wedge or SOHC wedge, 4 = Flat angle parallel valve OHV or lower rent wedge OHV, 5 = Side valve, unworked. Pick the best choice form a rating 1 to 5.
Rod Ratio 1=~2.1, 2 =~1.95, 3 =~1.80:1, 4= ~1.65, 5 = ~1.5.
Take the rod length, and divide it by the stroke. If you don't know, ask.
Compression Ratio 1= 15:1, 2 = 13:1, 3 = 10.5:1, 4= 9:1, 5 = 6.5:1
**Valve Size. Take intake valve size, and divide by bore size. 1= 0.54 or greater (4 or 5 valve per cylinder exceeds this often), 2= 0.50, 3= 0.47, 4= 0.44, 5 = 0.40. Pick the best choice form a rating 1 to 5. Side valves should use 5, because some valves are bigger but don't flow as well.
These 9 factors all get summed together to get a number, and then a scale factor is applied depending on the average of all 9 factors. So if you get a 41 for your Side Valve Ford 221, the average is 4.55. For the 1,2,3,4, and 5 averages there is a number you use multiply the sum of the nine factors.
For an average of 1, multiply the sum of the nine variables by 362. For 2, multiply by 250. For 3, multiply by 204. For 4, multiply by 228. For 5, multiply by 265. For anywhere in between, use math or make an approximation.
So our 221 Flattie, at 41, gets a multiplier of (228+265)/2, or 41*246.5
This adds up to 10107. Take the cubic capacity of the motor in question, multiply it by the peak power rpm (often 10% ofF* the maximum safe rpm for the engine, but it can vary a little) and divide it by one of that 'K-factor' we've found.
221*3200 = 70 hp net
10107
Try it. I'll do some examples, but it works pretty well.
Eg. 1
Jacks six carb Cross-flow 206 cuber.
Ratings were:-
Intake manifold efficiency= 1, (straight line tube, IR intake)
Degree of Carburation =1, (state of the art Motorbike CV's)
Camshaft Intensity =3, (wild street cam)
Head Flow =2, (stock with rebuild for lift and duration)
Exhast =2, (off-the shelf or simple custom)
Valve train configuration =2, (stock or roller rocker, altered for lift)
Rod Ratio =5, ( stock 1,505:1)
Compression Ratio =4, (About 10:1)
Valve Size =2. (**1.80/3.740= 0.48 or so )
using a score of 23, average of 2.44, multiplier is about 227. Hence the k-factor is 227*23, or 4994.
Rated at about 268 hp at 6500 rpm using this method.
So there you have it. A way of getting a power output without a dyno or the engine analyser.
*Edited. You guys were dead right. Take the maximum rev range, and often, the peak power is 90% of the maximum, or 10% off the maximum rpm for the power curve peak. It does vary a little. Sometimes its 80% of the maximum, or 20% off the maximum rpm for the power curve peak. Great to know you read this stuff gentlemen!
**And the valve sizes are divided by the bore diameter to get the valve size factor.
RemeMber this?
Take the cubic capacity of the motor in question, multiply it by the peak power rpm (10% ofF* the maximum safe rpm for the engine) and divide it by one of the following factors:
7000 if your six is box stock,
6000 if its got a good street intake manifold and exhast,
5500 it is worked with a cam that is over 260 degrees and very good breathing,
5000 if it is worked to an expert semi-race spec and
4500 if its a full-house, gas flowed, carb'd 300 degree + cammed motor. An electronic injected motor with Hillborn-style induction, very long rods, short stroke, and an A3 NASCAR/Cleveland style head that really flows might hit the 4000/3500 mark.
This gives SAE net (installed) power figures and works for most six and V8 motors.
Here goes
10107
Eg. 1
Ratings were:-
