i have a bad cam/lifter the #3 cylinder's exhaust valve is not opening all the way. i had to drive it to work all last week like that. it drives fine as long as i dont go over 2500 rpm, then it starts backfiring, will my engine be ok if i continue to drive it carefully? oil psi is staying around 30, the temp is staying normal but im worried about warping the head or damaging the connecting rod, should i get a rental car or will my engine be ok to drive to work?
