How do I check to see if the vacuum advance is working?
Pete W
I looked in my manual and it says use all of this detailed procedures and equipment to check it. Is there an easy way?
Also, what type of vacuum gauge to recommend buying? One that I could use to tune the carb and see if the engine is working properly.
Thanks,
Pete
1961 Comet, 144, 2.77 three speed
Something like this will do the job. This one has the extra stuff with it to bleed brakes which you may or may not care about. You should be able to just get the pump with the gauge on it. Any auto parts store as well as places like Sears should have them.
http://www.harborfreight.com/cpi/ctaf/d ... mber=92474
A shop manual should give you info saying how much advance for a given pressure. For starters you just want to put vacuum on it an make sure it doesnt leak and that it moves freely.
It is a little more difficult if you have the steel lines to the distibutor but probably the easiest way just to see if it is working is to disconnect the vaccum line and install a rubber hose. Take the distributor cap off and with the engine off suck on the end of the hose and put your tongue on over the end of the hose. The diaphram should hold vacuum. If it does not the diaphram is leaking. When you suck on the hose, look down at the distributor, the plate should rotate slightly as you apply suction to the hose. If it does this and the diaphram does not leak it is probably functioning properly. You put the distributor cap back on and start the engine. When you suck on the hose, the engine rpms should pick up. If you have a timing light you would be able to see the timing marks advance as you apply vacuum.
I assume you have a Load-a-Matic distributor which does not have a centrifugal advance mechanism. You may not need to disconnect the vacuum line to see if the advance is functioning. If you have a timing light, you can see if the timing marks advance as you increase the engine rpm which increases the engine vacuum. If you have the Load-a-matic and the timing advances with increasing engine rpm, then the distributor is likely functioning properly.
Doug
I found this the hardest thing (aside form adjusting my wacky choke) on my mustang...good luck. I gave up and had someone do it for me
I agree with 66 Fastback, either it works or doesn't, and his (or her, don't know) way will tell you.
No offense man, I've gotten flack when I referred to someone as "him" and found out later it was a "her".
