mustang1967
This is a 1967 Mustang with 200 Six stock ignition system. It has the correct SCV autolite 1100 and Load-o-matic distributor.
Car has rough idle, dies on deceleration after pop pop sound in mufflers. Runs rough and misses when revved up.
I have had this car for over 10 years so pretty good at the simple stuff. Here is a list of all I have done to rule out the easy fix.
New points, cap, wires, condensor (coil is not old) verified good blue spark at coil wire (off block) and plugs (with spark tester). Has 10 volts at + side of coil when running as it should (ran wire from battery to coil direct anyhow to make sure this is not the issue) .
Triple checked plug firing order. Installed new PCV valve.
Sprayed carb cleaner around hoses, carb etc to check for vacuum leaks. Adjusted points to factory setting with dwell meter. Tried other settings just incase (more gap & less gap).
Verified timing with light. Tried different timing settings by ear. Verifed timing stays constant with light at idle and when revved. Sucked on hose that goes from carb to distibutor changes speed of motor as it should.
Changed fuel filter. Has manual choke that is working properly.
The carb is a recent rebuild and has been running great. I took the top off 3 times to verify and adjust float setting, make sure no crude etc.
I used my vacuum gauge and it is pointing to a problem. Only showing about 13 pounds and this says it is "late ignition Timing" I have used this same gauge on this same car, t'd in the same way and had about 19 or 20 pounds. This is the normal range.
This motor was rebuilt about 20,000 miles ago. I did a compression test a couple years ago when I was having another issue and it was in the 190 range for all cylinders. There is no smoke or engine noise so I doubt it is in the bottom end. This is a weekends only car with not a lot of miles driven.
Head gasket or valves? Not burning oil or loosing coolant. I'm really thinking it is going to be valve adjustment. Does this seem logical? Guess I need to pull valve cover?
Any advice or ideas really appreciated. Will follow advice and post results till fixed. Please help! Thanks a lot in advance.
