Ok this is gonna sound ignorant at first but perhaps im just missing something. I always hear about someone changing rods or pistons and milling the head or block to change the compression ratio. This sounded ok to me at first bu tnow that i think about it. Im thinkin its not actually changing the compression ratio. If you have different rods or pistons, all you are really doing is movin the stroke farther up the cylinder. the length of strole stays the same. Also with milling you reduce the chamber volume so your compression ratio is not changed again. So im thinkin the only tru way to change comp. ratio is to change your crank. Im prolly missin somethin and havin a brain burp but its drivin me nuts lol.
thanks all
