Rule 1 of carby selection
http://fordsix.com/forum/viewtopic.php?p=50275&highlight=#50275":24prhuda said:
Smallest carb venturi area for resonable performance:-
Cubic Inch displacement divided by 115
Best carb for performance and economy compromise:-
Cubic Inch displacement divided by 70
Best carb for maximum performance:-
Cubic Inch displacement divided by 34 to 57. Use the smaller number if engine is able to rev above 6000 rpm, use larger if engine is not likely to go above 6000 rpm
If you have a 250 cube engine, you need 2.17 sq inches of venturi area. One 1.675 " venturi is fine.
Rule 2
In order for gas to be pulled into the engine, a pressure drop from the venturi to the throttle bore must be present. That is, the venturi must be a size smaller than the throttle blade. A factor of 1.35 creates a great signal, while on some carbs, like race spec 32/36's, can go down to a minimum of 1.06 on the primary side. Ideal difference is about 1.16 to 1.10.
For the best performance, a 1.84 inch throttle blade is ideal.
In practice, a 1.75" hole in a log head is ample. If the existing carb has a 1.75" throttle, you can ream away to about 1.59" without ruining the carb. Past 1.65", your carb will stop metering fuel.
When you take the swanky hips of a carb, it ruins the gas/air metering, and drilling jets and fiddling with idle circuits always results in poorer results unless you have a colortune, a gas analyser or wide angle oxygen sensor to read the mixtures.
Best of Colonial Fortune to ya, old stick!
