I have a 66 Mustang with 200ci and DUI distributor.
Long story short, I took the distributor out and totally lost the timing. I now can't get the car to start or even know where the timing is at.
I don't know if the timing mark on the crank is correct - with a timing light, the engine used to run well with it about 20 degrees before TDC.
I tried getting the timing mark back to about where it was at, then pointing the rotor to the #1 cylinder spot on the cap. It started but ran HORRIBLE - sounded like the engine was going to tear itself apart. I stopped and tried again. And again. Maybe I was 180 degrees out on timing?
Tried rotating the engine 180 degrees and then pointing the rotor at the #1 cylinder again and it wouldn't even start. Sounded like it was back firing out the carb? Maybe the engine was flooded? I fumbled around for an hour, trying different things until the battery needed to be recharged.
I gave up for the night and had a beer... hopefully I'll be more clearheaded and less frustrated tonight.
Any advice on where to begin? How can I figure out whether the engine is at TDC or BDC? How would I install a distributor if an engine where I have no idea where I'm at?
