Just an update: today we took the old engine out of the boat, and started swapping the marine bits on to the new engine. But we hit a snag...
How do i get the dog clutch off the crankshaft nose on my marine engine?
We heated it with a soldering blowtorch for 10 minutes, but that didn't help. Any ideas?
joel510 said all i need to do is heat it:
I think you'll find the cranks are the same. Most of the long motors in ski boats were unmodifed car engines with marine kits.
I have an EFI X-flow in my boat that also drives from the front of the engine with a dog clutch.
It uses a dog gear which is grub screwed to the crank. You'll have to heat it up to remove it though as they're heated up to fit. I know both the Tawco and Rolco marine kits use this method with their dog clutches.
Your best bet would be to replace the short engine. It'd be the cheapest and most hassell free IMO.
