This is what is referenced in the initial post as the write up on the installation process with pictures. When I click on this link it shows it as not valid. Don't know if the info has been moved.
i am planning on switching the distributor this week but wanted to double check that an 1980 Fairmont duraspark II ignition (single vacuum) will fit in my 170. i know it is basically the same block but want to make sure. thanks
Oscar
