How to remove the crank with out removing sump?
Does anyone know how to remove the crankshaft out of a 250 without removing the sump, head or timing gear?
Unless you have in mind to cut it out in pieces or dissolve it with acid, no. :wink:
You have to drop the sump to get at the main cap bolts. The timing gear and chain have to come loose to get it free of the cam.
Sorry to waste youre time but its seems that anyone can answer just about anything on this forum. Took the liberty of putting this in for laughs. Id use an angle grinder.
I once removed the crank through the radiator when my power steering was leaking.
I then smoked the rest of the joint and ajusted the roller rockers through the tail light!!
Very special talent i have.
:shock:
Head downhill with foot to the floorboard. When you reach terminal speed, downshift. :shock: Oh, yeah, make sure your seatbelt's on tight. :wink:
once removed an engine without removing the bonnet(hood)!removed the front suspension(with a gas axe)and lifted the car up over the motor and front end!!like to see someone get the pistons out with the head still on!!
