Well, I've had this 1960 Comet with a 144 cid a for a few months. When I got it, it had sat for several years. After replacing the fuel pump, carb, plugs and wires, I got it running. It was running rough but running nontheless. I've never rebuild an engine before so you experts can give me some advice. While it was running, I pulled each wire to see if I was firing in all 6 cylinders. I was getting no change on the last three cylinders (the three closest to the firewall). Upon compression check, I got zero in one, 135, and 55 in the last cylinder. So I'm guessing it's time to break her open for a rebuild? I'm a quick learner and have done most everything else on car besides engine work. Would yall recommend me having a professional do my engine work or does this sound like something I could do and learn with the help of a good book? Keep in mind that I'm not really looking to really supe it up. It will just be used to cruise around in on weekends. Thanks in advance for you opinions.
