Didn't know if I should have started a new thread but here goes.
I have a 65 mustang 200 ci 78 block with a 2.77 3 speed trans with 8.5 inch flywheel/clutch with a early small bolt pattern style bell housing and I believe it had the wrong starter on it because it chewed up the ring gear. I took the trans out to replace the ring gear and found more problems. The flange on the bell housing that holds the bracket for the clutch fork spring broke off when i took the bolt out. The flywheel is bad (too thin) the pressure plate is bad, release bearing is bad, clutch disc is still good. The previous owner had a new clutch installed and the installer had to know the flywheel was too thin but maybe they couldn't find another one and had it machined anyway then let it run. So now I have a bell that needs repair, bad pressure plate and release bearing in addition to a bad ring gear and starter....great.
A while back I bought a 66 mustang 200 ci 2.77 trans as a spare and it was bad so I scraped it and kept the bell, good 9" flat flywheel and block plate, bad clutch kit for a refence. I was going to use the 66 bell and flywheel since my block has the duel pattern and I have to find and buy less parts. I had the flywheel resurfaced yesterday and last night i ordered a 9" clutch kit from Rockauto. I know I should've done this early but today I found that the bad clutch disc from the 66 2.77 trans has a bigger inner diameter and will not fit my input shaft on my 2.77 C4OR-7006-A casting number trans. CRAP! I thought that all 2.77 trans were the same diameter since they 10 spline so now i have to cancel the clutch kit order.
Where can I get smaller diameter 9" clutch kit (disc and release bearing) that will fit my earlier 2.77 trans with the smaller imput shaft. Is there one available? If not then I Guess I'm stuck with the 8.5" flywheel/clutch. And i need to find a good with enough thickness to be turned without being too thin. I wonder if another member on here had one because I can find one where I live and on the internet. I'm really stuck between a rock and a hard place now. i would like to do a T5 swap but I cant afford that for a long time so im just trying to get the car moving again. I really need some advice from you guys on what direction i can go and thanks for reading my big spill.
