Howdy.
I have a 1966 170 Engine that I just dropped into my 63 Ranchero.
Originally - the vehicle was a 144 with a 3 speed on the tree.
Now - it has the 170 - and a C4 automatic.
So - I think I just learned that my 170 has a manual trans carb on it.
The one I have on the engine now is labeled C6TF F. It has an attachment
for a manual choke, and no dash pot. The attachment for the throttle is also way too high to be picked up by the gas pedal linkage.
Here is the carb on the engine now:
170 Carb
I have an older carb on a junk 200 (engine and carb both need to be rebuilt) but it appears to have the throttle in the right location, it has a dashpot on it, and an automatic (heat actuated) choke. Even if this carb was in good shape, I would assume that the 200 carb would not work well on the 170. This old beat up carb is labeled D0PF K.
Here is the carb on the junk 200 engine:
200 Carb
So...
The question is - what carb do I need for this new setup, and where would I be able to get one? Basically, I need a 170 carb for an automatic with the throttle connection down low.
Thanks!
-Zim
170 Carb
200 Carb
So...
Thanks!
-Zim
