barishiman
We'll after much frustrations we had a friend come over and help us out.
This is what I got to re-iterate:
a. Pertronix Ignitor II w/ flamerthrower II ignition coil
b. Holley 5200 on Clifford adapter
c. 3 row raditor w/ flex fan
d. 68 dizzy
e. 66 stock block and head .030 over pistons, redone head with 1.75 intake valves, 3 angle valve job, new springs and valves
f. new oil pump
g. 7mm wires
h. FSPP Pacemaker header
i. Bosch spark plugs
j. stock C4 auto trani
So here's a list of what went down:
1. The pushrods had to loosened abit
2. Inspection of dizzy and Pertronix unit
a. I took the Pertronix unit out and made sure it was the correct one, which it was.
b. I then re-installed the Pertronix unit and it still rubs on the plastic sleeve with the green nylon tape. It was troublesome just the get the unit to sit correctly. I installed the unit where the points were. I did notice that it was sitting atop of the vacuum arm thus it is tilting the Pertronix unit into the sleeve. I thought maybe we could shave off some of the metal off the unit, but no. The actual Pertrnoix unit is sitting atop the vacuum arm. I attempted to move the unit around, but there was no where to fasten it down. So I just installed it and put the dizzy back in the car.
c. Installed the dizzy on the compression stroke of #1 and the rotor set to #1 on the dizzy cap. Ran all the wires and none were crossed.
3. It fired after a couple of tries and man was it loud. However we couldn't hear the lifters clicking. We tried to adjust the pushrods while the car was running but that failed. So we shut off the car and did it by feel. Cranked it up and it ran alittle smoother.
4. Then we pulled out the timing light and adjusted the timing to 12°. We did move it to 14° and it ran smoother but kept it at 12°.
5. Adjusted the idle on the carb. It was idling extremely fast. After messing around alittle with the carb, we got the car to idle fairly well at a slower speed. However, I can't tell how many RPM's were pullin (no gauge).
6. After harming up the car, we decided to put it into gear. Well that killed the engine and that's where I am now. The car refuses to run if I put the car in gear. So I thought of the things below that could be causing this:
a. Off the top of my head, the tranni was moved up and down a lot while working on the engine bay during the cleaning process. A whole lot of tranni fluid was lost. I put more tranni fluid in before we started the engine, but knowing how much was lost is impossible. Also during the installation of the engine, we had trouble with the torque converter mating with the engine block. We moved the torque converter around until it finally slid back into the tranni and the engine could mate. So I'm guessing maybe there's something wrong with the tranni?
b. The Pertronix unit and its air gap that is needed (.030"). It ain't happenin fellas. I might be able to modify the bracket that it's on, but it's going to be close. The pertronix unit for my 65 dizzy was fine during installation, even had the gap, but yes that is a different dizzy.
c. Could the valves still be too tight still ? We are thinking of loosening them again a 1/8 to 1/4 turn.
d. Should the timing be adjusted to 14° or where should it be? Would the timing be afftected with all the modifications made and does anyone have a suggested timing degree?
e. Possibly the alternator is fried after one of the wires melted. The wire was a black/ yellow stripe with a black plug. I have no idea what it was and my build manual doesn't tell me what it is. But all is good, seems it was a wire not needed and the engine has been able to start. I will take the alternator off and get it checked sometime this week.
I think that the Pertronix unit is one of the main problems and maybe the valves has something to do with it. So this is where I ask for advice and where I should go next. I'm also attaching some pictures.
Here is a picture of the coolant lines. I've attached the fuel and vacuum lines to the coolant lines. Do you think that by running the fuel line along with the coolant would be causing vapor lock because of the heat of the lines?
Here's a pic of the Pertronix unit.
All you guys have been a great help! I'm a novice at the whole engine thing, but I've been trying to learn everything I can. If I fail to mention anything, it's my fault and sometimes I forget or don't know how to describe the situation. Let me tell you this, if I didn't find this site, I would be in deep $#!t.
THANKS!!!!
Andrew
d. 68 dizzy
f. new oil pump
g. 7mm wires
THANKS!!!!
Andrew
