The 6 Cylinder kick down linkage on a 65 Stang consists of a "Kick down bar" that is attached to the stock gas pedal bar that runs from the gas pedal, through the fire wall to the carb. This "kick down bar" has a wire lead connected to it that is threaded on one end and has a connection point on the other. The connection point is attached to the kickdown lever on the transmission, the threaded end is connected to a fitting, and these two items are adjusted to help determine when the transmission is actually "kicked down" into the passing gear.
This is an over simplification, but I hope it helps.
Kurt.
