large Oil Filter
66Sprinter
I searched but cant find the post with the part number for the larger (longer) oil filter that lets you use 1/2 quart more oil. Anyone know?
(Not aware of earlier post, but you may find this of use)
Best filters seem to be those by:
Donaldson (#169071)
Baldwin (B2-HPG)
Wix (51515)
The above are the FL1A/PH8A size.
The Wix 51773 is extended length.
Howdy Jammer:
The larger filters you're looking for add a 1/2 quart to the total capacity of the system.
AC PF42
Ford FL-299
Fram PH977A
NAPA 1773
Purolater R17
Wix 51773
I didn't see the earlier post on it, but David is right, I'm sure your looking for:
Swith your ford one from the FL-1A to the FL-299
you can also use any of these other brands:
AC PF42
Fram PH977A
Wix 51773
Purolater R17
Any of these will move your capacity from 4.5 to 5.0 quarts.
If the parts guys give you a blank look, ask for the oil filter for the 361/391 big truck/industrial motors. Take care,
Edwin
