The filter I'm using is a Motorcraft FL 820-S. It's wider than the adapter housing, but there is a skinner filter, which I used on initial break in. It is no wider than the outer rim of the adapter. It's Motorcraft FL 500-S. The adapter filter threads are metric, the FL-1 filter will not work. If you have 3 inches of horizonal space between the block and the steering box there's room to spare. The vertical depth is about 5 1/2" from the block filter nipple to the bottom of the filter. In the pic I added an inch which about how much longer the FL 500-S filter is.
