Leaking gas..
I was jsut out starting my Stang..and it was leaking gas..on to the valve cover..and ideas?
Probably a leaking hose or connection. Also, is your carb all covered in soot? if so, you may have a leaking gasket on your carb.
Slade
Thanks, Ill just check it out later when it's light out there.
my hollet leaks from the throttle shaft. will drian the bowl in a few hours then it is a pain to start. only does it in the winter really. wanna get one of my 1100's on it soon
