It seems that there is many opinions about how to do the linkage on the 5200. I have a 65 fairlane with the push type throttle linkage. What is the recommended way to hook up the 5200? Thanks.
I am working on a 5200 on my 62 fairlane and have the same push pull linkage. if you jet it right it will run ok. since the 5200 runs on only the primary on cruising just jet that normal and set up the secondaries a little lean to account for the fuel slosh. just mount the carb sideways and everything should bolt up ok.
I haven't put pictures of the carb setup yet. I will probably today.
I think the fuel starvation issue is related to float levels. Also, it's something that people talk about, but I only recall one person every posting an issue about.
I set my float level up to stock, and I've never had a problem with starvation. I also had my carb tuned with an 02 sensor and my fuel mixture levels are right on!
