LameHoof65
Called a couple of local machinist's both said they could do a mill, 3 angle valve job put the Valves, Seals, and Springs in for about $120.00. Sounds real good to me, but then I have never had this done before. I am thinking about leaving the stock valves in the head and changing out the springs, retainers and going to the chrome moly pushrods. I am looking at putting a dual pattern high lift cam in as well and this leads me to my question/s. Do I need to invest in a roller rocker and/or something that would give me higher lift or can I keep my standard rocker. This is not the head I am trying to fab for the fi, but the one I plan to use with the Holley 500/2300 setup. I want performance but this is only an interim upgrade so I don't want to over do it $$$ wise. I haven't CC'd this head yet and I don't really know it's quality...One of the machinists stated that he would mag flux & completely clean the head before starting the rebuild. I would like to put it at about 9.5 to 10:1 on the compression but no more. And finally, because I am not planning on reving over 6000 any time soon do you all think this setup will hold up?? I know in the Fordsix handbook Ak apparently used the original springs with T/C'd engines with about a .030 shim and he could get it to withstand a 6000 rev... I am not sure which cam but something around 268/270 duration I am not sure about the lift either... but I want it to pull strong through about 1500 to 5000. Help me out---I am in over my head here.
