Look what I found under my valve cover!!!!
Mercury Mike":t1y0rtkf said:
Knowing me... I'd fill it full of ATF and just crank it over a bit, then pull the oil pan and just get all that junk out, run a couple of clean quarts of oil through it with the oil pan and catch it all, then put the oil pan back on it, fill it full of 5w30, and a quart of lucas just for extra lubricant, and fire that bad boy up. I have so many 200s in my back yard after all this time that I don't even think twice about blowin' 'em up anymore. I've got 2 completely rebuilt ones and only one 6 cylinder car these days!!!
I'm with you, except that I'd pour a couple gallons of diesel through the block instead of oil.
At worst it'll lay down and die, then you rebuild it anyway. My money is on it running like poop for the first ten minutes, then settling down and running ok. Tough engines, these Ford Sixes.
...Wonder where he's located...? I'd be down to start it for him! But yeah, worse case scenario it lays down and dies. I love the fun stuff like starting old engines like that.
He is located in Virginia.
Originally Posted by fakesnakes (on another forum)
"Okay, to rebuild a 6 cylinder is more costly than it is worth unless you are doing a complete concourse restoration. What you are looking at is oil sludge for the most part. The rust is from moisture in the oil and the dampness of a barn over 18 years. Scub it down with a good solvent wash all that crap out of there and let it fall into the pan. Use plenty of solvent and run it thorugh the oil drain back openings until you are sure it is out. Remove the pan, scrub the rest of the crap out, rinsing well and replace the pan and gasket. Fill it with a good quality oil. Shoot two good squirts of Mystery Oil in each cylinder and turn the engine over by hand several revolutions. Change the plugs, points, condenser, cap, rotor and wires. Crank it with the starter and listen for and strange noises. Finally, start it up and let it run at various RPM until it is warm."
I'm thinking fakesnakes might be right here. I've already got new Ignitor/Flamethrower ignition/coil, and replaced all wires and plugs. Carb has been rebuilt. I looked down the plug holes with a light and it was nice and shiny in there (from what I could see) I'm gonna do the above, and see what happens. Then I'm gonna start looking for a new engine to put in there! I'll keep you posted with pics!
JHP
At first I thought were going to say you were giving up on the six, I'm glad you didn't. Congrats you've passed the first test....not listening to the nay sayers.
You would be surprised what this engine can do...it is a tank. When I first bought my Mustang back in '87, the engine was so gummed up and out of tune I couldn't get it up faster than 30 all the way home (and it took about a 30 second to get to 30 mph).
IIRC, my father and I just kept adding ATF and changing the oil for a weekend watching all the sludge come out with each change. When the oil changes stopped looking like used coffee grounds, we gave it a quick tune-up and it was a different car. I drove the car all through high school after that with no problem till we rebuilt it when I was in college.
That's what I'm talkin' about!!!
Thanks for the support. Gotta have faith baby!
I'll keep you posted in the next couple of weeks.
For your continuing entertainment...
After using solvent and a toothbrush (my wifes:)) and rinsing well with a total of about 3/4 gallon of solvent, here's the progress:
http://s448.photobucket.com/albums/qq20 ... 281021.jpg
http://s448.photobucket.com/albums/qq20 ... 281020.jpg
http://s448.photobucket.com/albums/qq20 ... 281019.jpg
I let all the solvent drain in to the pan, and drained it, and flushed with more solvent. The solvent that came out was red instead of clear. After a day to evaporate the solvent I will flush with oil and, and fill it up with oil and Marvel. Then I'll lube the cylinders with Mystery oil and crank it around by hand a few times. Repeat daily for three days. Saturday should be D-day. (fingers crossed)
For all you naysayers... If it doesn't work you can say "I told you so" but I've gotten enough encouragement to try it before I give up on it. I'll keep you posted.
JHP
Hey I don't think you got any 'naysayers' here...especially when it comes to a Ford straight six :wink:
But it wasn't a question of whethor or not it would run. Instead it seemed to be a question of what should I do (ie what would you do). Naturally when you ask for opinions you should expect 'em to run the gambit. I'd take that as a healthy difference in approaches. Some would opt to clean it up and run as is, others would choose to go ahead with a rebuild. I'm sure everyone here would wish you success, because I think we'd all liike to see another six on the road :) IMHO. I suggest we keep it friendly cause it's not an us against them kinda deal. Myself, I wish you luck...but 'if I were you' (obviously I'm not :P ) I'd still pull the pan to finish the cleaning and to make sure the sump doesn't clog right out of the gate (my .02)
Good luck!
Looking good! I'd pull the pan and check the oil screen as well.
I'm betting it's gonna run just fine with a tune-up.
I just put the pan back on about a month ago after a full cleaning and repainting. The screen was in good shape. Would you pull it again?
I'm not being unfriendly, I appreciate all opinions. I guarantee everyone on this forum has more experience with this sort of thing than me. I'm keeping it light hearted :) Don't take me too seriously :lol:
I'm off to turn the engine by hand. I did it this afternoon after pouring a bit of Marvel Mystery Oil in the plug holes. It turned pretty easily with a box wrench, no breaker bar needed. I saw the bottom end (I think?) when I pulled the pan last month. It was almost completely rust free. Keep the good advice coming. I can take it!
The only reason I'd pull the pan is to make sure that I got all of the solvent out. make sure it flushes properly, etc. But it's up to you. Let us know how it goes! If I were you I'd start it already, I'm impatient haha
Yeah I was thinking about just pouring a quart of oil through the head to flush all the solvent and let it drain right out. Then fill it with new oil plus 1 qt Mystery Oil and see what happens. It's amazing what the Mystery Oil already pulled off the cylinders, from what I can see through the plug holes. I'm impatient too, but one step at a time. Tonight I put the drivers seat back in so I can sit while I crank it. :lol:
honestly your engine looks better than previously but i'd defenetly pull it again to clean the screen, but i'd wait until you have it running letting the screen flush the oil a bit to make sure most gunk is out of the top engine i'm sure some gunk fell down somewhere... but that's me...
when starting it i'd run 1~2 quart ATF, like some one else posted to clean up anything/everything possible
hopefully it runs just fine..
Richard
You should take a video of it with a digital camera, I'd really like to see it start for the first time after all this haha.
I'm definitely gonna have the camera running. This weekend! Spring break is next week, so I'll be getting some things done..I hope!
