First I want to say thank you to everyone for the DuraSpark ignition upgrade info. I was able to get all the parts I needed from a local parts store and make up my wiring harnesses using towing connectors (their water resistant and I couldn't find a salvage yard near me with a Fairmount).
I only had one problem when starting the car after installing the new distributor and ignition system. I only got a spark when I first started cranking the engine and when I stopped cranking the engine. It turns out the switched 12 volt source I used drops out when the ignition key is turned to the crank position. To make sure everything else was working I connected the ignition module's power lead to the coil's possitive lead (I know its only 6.5 volts) and the car started right up and I took her out for a test drive.
Now I've gone searching for another 12 volt switched source, but have yet to find one that doesn't drop out when cranking over the engine. The wire from the ignition switch to the coil on the '67 as far as I can tell has the resistor in the switch (let me know if I'm wrong for '67). So I can't connect in before the resistor.
Any one know of a good switched power source? Or should I just run the module off the 6.5 volts from the coil. Is there a down side to using the coil power source?
Thanks,
Greg
Thanks,
Greg
