All Small Six lost compression on 2 cylinders.
Dragonlich1961
Unfortunalty- looks like my Sunshine is down for the count. Awhile back I drove her to work, and went home on a trailer. funny oil pressure, and a gallop when on the starter. Compression test revealed 70(1),40(2), 165-170(3-6). Leakdown test seams inconcluive. No leakage through the intake or exhaust. No cross leakage- so head gasket seams ok. So that leaves- rings or hurt pistons. GRR. Good news, i get an excuess to use the Aussie head on my shelf. about 4k mileage the build.
Any ideas on what failed, I don't have the space to pull it apart father at the moment(currently have my daily gen 3 hemi apart for cam failure). No aparent marks on the cylinder wall that i can see(small bore scope), decent amount of oil on the plugs but i've been fighting the vintage inlines cover. (I thought my welded in baffles were enough but no.)
Could be a valve train issue, pull valve cover and take a look. It can cause a symptom like that.
  • Like
Reactions: DON
Update-- long over due, I've completed a leak down test, with passed- intake, and exhsaust. All blow by in crank case. Pulled the head, and pistons look ok, cylinders look ok. So some how i've pinched or fired the rings in 2 cylinders. Grr only thing i can think of is my early stuggles with pining severly. Everything looks good, so i'm hoping to get away with rings and a hone. Looks like i get to finally toss my 250 2v head on.
Update-- round 2. Finally found the time to deal with repairs- spent most of my winter redoing the garage so my Sunshine has been parked in the corner while i work around it.
Finally got a chance to pull the oil pan and remove pistons 1 and 2. Tally- not 1, not 2, not3, but 4 Broken rings. Some how I've managed to break both the primary and secondary compression rings on both pistons. The only cause for this that i can think of is the seroius run of detenation that i have been fighting. Review some of my old posts( about 4-5 years ago) and i was struggling with bad lean conditions into the 16/17:1 range. (i have a afr gauge). If 17 is the average then there has to be a number higher, and I think we found where.
I'll be ordering a full ring set and re ringing all 6.
also discoverd that pistons 1/3 have a mark in the top of the pistons, likely from the valves. This most likely happen years ago when the timing chain came loose(my 19 year old self's fault- I put the cam wedding ring on wrong). Never ran weird after the repair- but not something i would have thought could have happen.
glad you're making progress! Always feels good to get back on a waiting project.
#2 cylinder is always leanest on all I6 engines with a common-feed intake, caused by the physics of firing order.
you may have had too small a ring gap, another possible cause. Since those cylinders were too lean= hotter, rings may have butted.
