TrickSix
Falcon Six Performance Handbook for sale. Great condition. Comes with a parts pile. I don't want to nickel and dime the small stuff. No shipping, bring a truck and pick up in southern Minnesota. It's also being advertised locally. This supersedes and includes everything in any ads I have now. All parts are for six-cylinder cars, non-engine parts are for a '66 Mustang. There's an E0 head, completely rebuilt, with new valves, guides, stem seals, standard springs, 52 cc combustion chambers, 3-angle valve job with the intake valves back-cut, and everything that bolts to the head, including head bolts with washers. Rebuilt non-adjustable rocker shaft assembly and pushrods, valve cover, filler cap, PCV, thermostat housing and thermostat, temp sensor, carb spacer, rebuilt 1101 carb with dashpot, adjustable throttle link, choke tube, some extra jets for tuning the carb, and custom air cleaner. I was going to use this one as a low rpm automatic transmission car head. For a manual transmission car that will see higher rpms there's a C9 head with new seats sized for 1.75 intake valves and 144 intake valves used as exhaust valves. Has also had some port work done to it. Work was done by a well-regarded engine builder in Minneapolis. Includes a good adjustable rocker assembly and pushrods, new valves, new guides, new stiffer springs and one piece 221 retainers, carb spacer and t'stat housing, and a valve cover. Needs a valve job and mill to your desired compression ratio. There's a D5BA-6394-AA bellhousing, 9" clutch parts, flywheel, starter, and engine plate in case you want a manual transmission. A NOS camshaft. A NOS fuel pump. Three more rocker assemblies, one non and two adjustable, plus some more pushrods, both varieties. A couple of DuraSpark distributors and coils, one with box and wire harness. A C9 dual-advance single vacuum diaphragm distributor. A new Pertronix Ignitor II. A newish 1100 carb and a box of junk carbs and parts. An "extra cooling" air conditioning radiator and six-bladed fan. A C8 exhaust manifold with the 2" outlet. Two front hubs with new studs and bearings. Several carb spacers, including a pipeless '68 and another large log spacer. Nine loose adjustable rockers - scrounge three more and you can convert a non-adjustable assembly. A dozen NOS 240 police/taxi exhaust valve springs - stiffer than the stock ones. Seven new 1.75" intake valves and several sets of used valves and valve springs, some head bolts, and two sets of the engine lifting brackets from a large log head engine, one front one modified to fit the older 200 blocks. A valve cover. A gas tank, rear bumper, and rocker trim. Other misc. pieces and parts, gaskets, and whatever I'm forgetting, there must be more. I'll get some pictures posted in a day or two... Whatever there is, it's yours. Take your hobby to a new level! (Probably about two feet higher in your garage.)
Oh, and all the parts for a Scarebird disc brake conversion except for the bracket kit you buy from them.
Note - If you just want a head, keep scrolling...
