Would like to run this by the experts before I pull the trigger;
I had a couple leaky freeze plugs on the head so I decided to pull it to repair and while at it check the compression The head is a C9DE-6090-M with 1.39/1.75 valves, hardened seats, 3 way valve grind , new guides, etc.... We also 0.0" decked the block. That being said, we only resurfaced the head. ( The guy who rebuilt my motor was very knowledgeable with motors just not an expert on these straight sixes) So I tested the chamber CC and came up with 58cc. Doing the math on a couple compression calculators (bored 0.060, .045 gasket, 0.0 deck, dished pistons, ) I have 8.7:1. A little to low, from my understanding.
So my questions are: After doing the reading, I'm thinking I should be around 9.4:1. ?? Which would mean I would want to have a 52cc chamber and need to mill off .030 ?? Is this all correct?? Also why does all the online compression calculators come out about the same ( 8.74 +/-)) except for the CI chart??? (8.53) Since I only have 20,000 miles on the motor since it was rebuilt, Is there anything else I should do to the head while it is off and at the shop??
PS. I noticed my muffler is starting to rust, so while the exhaust manifold is off, I REALLY would like to get some headers
Any final word on those Speed Daddy headers???
Thanks!!!!!!
Thanks!!!!!!
