mustangsixty5
Hi I just recently put my Mustang together. I bought it used with a lot of work already done. Most of it was improperly done and I had to rebuild the engine due to this reason. I rebuilt the engine going 30 over, balanced, put a large log head on with the 38 Weber 2 barrel conversion done, 302 valve springs, roller rockers, 264 duration cam-unsure of other details but going by what I was told, Mallory Ignition system with CDI box, MSD 8.5 wires and MSD plugs, Dual outlet header with duals through xpipe through 2" resonators, ARP head studs and rod bolts. It runs very good overall without any hesitations at all but from idle it doesn't seem to accelerate as fast as I would expect. Other than from a stop the car seems to run similar to a stockish small block v8. Also I noticed when in drive the cruiseamatic trans pulls out in 2nd gear. It will pull out in first gear when you manually shift it. But even when in first it still doesn't meet my expectations. Any ideas on these two issues? I know the cam may be the issue here for off idle. I'm not looking to race it or I would have went the v8 route but an occasional burnout would be nice.
thanks
thanks
