... been following this thread since I have a H/W 32/36 on my built 170 with great results for @ 15 years. I did have initial tuning issues but not the idle problem. H/W Idle is consistent unlike Holley 1Bbl's.
I would recommend considering other issues related to idle before committing to the carb being central problem.
here's some old notes I have from 'stang200' @ 2005 from this or FCA forum that may help:
The Holley/Weber 32/36 carburetor is a great carburetor but can be a little tricky to set up correctly with a 6 cylinder engine. For those of you who don't know, the 32/36 was originally designed for a 4 cylinder engine. This is not to say that is will hinder any potential performance or fuel economy when used in conjuction with your inline 6 cylinder engines. Only a few changes or rather adjustments will more than likely need to be made for your particular application.
Jets. With a few minor changes to the stock jets, this carburetor will give you the performance, as well as fuel economy, that most others cannot deliver. Notice I said
stock jet sizes. More often then not, rebuilt Webers don't necessarily have stock jets installed in them during the rebuild. So, before you purchase any replacement jets, it's best to see what you have to determine what needs to be replaced. Each jet is stamped with the number on top or on the side of the jet themselves. They are a little difficult to see but a magnifying glass can rectify this problem.
Here is a list of jets and their associated technical names that should help you in determining the right set-up for your engine.
4 cylinder
Primary Main Jet 140
Secondary Main Jet 140
Primary Air Corrector Jet 170
Secondary Air Corrector Jet 160
Primary Idle Jet 060
Secondary Idle Jet 050
Pump Jet 050
6 cylinder
Primary Main Jet 160
Secondary Main Jet 160
Primary Air Corrector Jet 190
Secondary Air Corrector Jet 180
Primary Idle Jet 075
Secondary Idle Jet 065
Pump Jet 060
The first list is comprised of the stock jet sizes as originally intended by the manufacturer. Remember, these numbers are based typically on a stock 4 cylinder engine displacing
no more than 151 cubic inches.
The second list was developed from a group of off road enthusiates, namely individuals from the Jeep crowd. Typically their engines are 6 cylinders with displacements of 232 cubic inches or more.
I have found the latter jet sizes to work very well(save one size small on the air jets 185 & 175 vs. 190 & 180) with my inline 200.
The following write-up is from Weber.
SET UP ADJUSTMENTS
Start set up by confirming carb base line settings. Do not depend on the factory delivered settings. Check them before the carb is installed.
All settings are done with choke disengaged or warmed up so that the choke is fully opened and disengaged. This is done on automatic choke carburetors by first opening the choke butterfly by hand and inserting a wood block or wedge of some kind to hold open while the linkage is cycled (linkage operated through its full movement ) to clear the choke cam. (You will hear a metallic click as the cam is released. You can check the fast Idle screw under the choke assembly to confirm that it is not in contact with the choke fast idle cam.)
Set the Idle stop screw (speed screw see fig 1) by backing out the Idle speed screw until it is not in contact with the throttle stop lever. Cycle the linkage again to be sure that the linkage comes to close without any assistance. (Checking for linkage bind) Now bring screw back into contact with the lever and continue to open or screwing in 1 turn no more than 11/2 turns.
Set the mixture screw (see Fig 1) by first screwing in until the screw stops, bottoms out. DO NOT FORCE OR BIND AS THIS WILL CAUSE DAMAGE TO THE SCREW AND IT’S SEAT IN THE BODY OF CARBURETOR. Back out the screw 2 full turns.
TUNING
BE SURE TO FOLLOW THE NEXT INSTRUCTIONS IN THE PROPER SEQUENCE, DEVIATION WILL CAUSE THE CARBURETOR TO NOT FUNCTION TO ITS IDEAL SPECIFICATIONS AND MAY NOT PROVIDE THE PERFORMANCE AND FUEL ECONOMY AS DESIGNED.
Start the engine, the engine will run very slowly more like a tractor. As long as the engine stays running idle speed is not important at this point.
The first thing to do is not set up the idle speed, but to set the Idle mixture screw to lean best idle setting. First, turn in the mixture screw until the engine dies or runs worse, then back out the screw (recommend turning ¼ to ½ turn at a time). The engine should pick up speed and begin to smooth out. Back out ½ turn more, or until the screw does nothing or runs worse then turn back to the point where it ran its best.
Use your ear, not a scope or tuning instruments at this point. You want to tune the engine by sound. Adjust to best, fastest and smoothest running point.
Now that the mixture screw is at its best running location, you can adjust the Idle speed the screw. The screw will be sensitive and should only take ¼ to ½ turns to achieve the idle speed you like.
Check and set idle to your driving preference. Put the car in gear and apply slight load, (AC on) and set the Idle as you like it. Don’t set it too high, as this will cause causes excessive clutch and brake wear. The Idle only needs to be 7 to 900 RPM with light load or AC on.
Recheck timing and vacuum hook ups. Recheck mixture screw to lean best idle again. If all is still best and smoothest idle then confirm and note the final settings.
To confirm settings with the engine running. Start by screwing in the mixture screw and count the number of turns it takes to bottom out and note if the engine dies. If Idle Mixture screws are with in ½ turn of base line setting then all is well and have fun. Also check the speed screw and note how many total turns from initial contact. You may have opened (turned in) the speed screw. Your final setting should be under 2 full turns. Reset the screws (back in) to the best final settings (Per your notes) and go on a test drive and have fun. If the settings are other than described then you may want to recalibrate the Idle circuit (low speed circuit) to your engines needs. This is done by following the rule of thumb BELOW.
Simple Rules for low speed calibration
If the mixture screw is more than 2 1/2 turns out turns then the Idle jet is too lean (too Small). When the mixture screw is less than 11/2 then the Idle jet is too rich (too large). These assumptions are based on the fact that the speed screw setting is not opened more than 11/2 turns. If the speed screw has to be opened 2 or more turns then this is also an indication of a lean condition usually requiring greater change. At times it may appear to be showing signs of richness or flooding it is really a lean condition. See pictures and notes in the tech 2 article supplied in the kit instructions, view and please understand the need to keep throttle plate as near to closed as possible so as not to prematurely expose the transition holes. This is what causes the visible rich condition, and confirms the need to increase the jet size. JET KITS are available if needed.
