LPG with nitrous or octane boost
MRJLB84D
just wondering, with lpg, can a system similar to a water injection be fitted but instead of water have a bottle setup with some octane boost in it instead, can you mix LPG with nitrous or octane boost?
Thats a tough one.
I'd be looking at using a lube instead of octane booster though, LPG is between 100-110 octane I think.
Don't know about nitro and LPG though, but you only want the stuff for either strip or show, not much use on the streets unless you want to spend a bit of dosh each time you want to get to the speed limit as fast as possible.
xtaxi would be the one to ask.
You cant run a dry n2o system with lpg
you need a recirculating fuel system filled methanol
talk to the guys at GRA they will tell you all about it
and what happens if you dont
