I'm getting more confused with all this talk about differant sources of vacuum.....I spent some more time in the garage last night and here's some  more observations;
I pulled the hose off the PCV and plugged it (left in connected to the manifold inlet) - rpm went down 200 rpm. I tried a differant PCV and it did not change things.
I tried running it without the fuel filter- it seemed tad smoother, but not much. I put in a new filter- no differance. Could it be the fuel pump? (I think not as I did  not have this problem on the 170, and all parts I'm using except the new carb were on the 170) I wouldn't think the fuel pump going would cause high vacuum advance  :roll:
I changed cap, rotor, and condensor- no help. Disconnected vac. line to trans- no help.  I'm wondering if it is a fuel or mixture problem.
I have disconnected the vac. advance for the time being- the car does not run better, but at least I'm not going down the freeway with too much advance and risking damage. I can't hear if there's detonation due to the exhaust leak (getting fixed tomorrow since no headers avail. ) but plug tips are white now.
Today I noticed  that while at cruising speed, with vac. advance diconnected, if I pull out the manual choke the engine runs and performs smoother- not perfect, but better. Maybe the carb IS too lean- would that cause the timing problem
I am going to put the 1100 back on tonight ( had misfiring or "surging" going down the road on this 200 with it but not as bad as with the YF, not at all on the 170) and put the biggest jet I have in it to see if that helps. Doug said not to drill out the jet on the YF or that will ruin it, so if it is running too lean I'll have to figure that one out when I cross that bridge...
Addo said "What if the carb were designed to work in conjunction with a thermo-vacuum switch?" I'm not sure exactly what this means, but I know this is a non-thermactor  carb and dist. The distributor that was on the engine when I bought it had two vacuum ports- one was plugged. I am running the single advance dist. (from '68 mustang) that I had in my 170.
I know nothing about an allen screw inside the vacuum port (and there is only one port on this carb) but I will look at that tonight before I put the 1100 back on.
One other thing - The YF has an automatic choke but came without a tube, so I transferred the manual choke off my 2100 to the YF. I assume the choke tube pulls air through into the carb and thought this might act as a vacuum leak with no tube connected to the exhaust manifold, so I plugged it. It had no effect on the current problem, though.
So, the questions are; How do I know if the fuel pump is going, can I adjust the vacuum at the port, and will richening up the mixture (with the autolite 1100) help? I'm going to look at the latter two tonight.
Thor
PS- Is there something that could have been done wrong when the engine was assembled- like the timing gears not being lined up correctly, or something else- that could cause this?
