Total advance at about 32 deg, is indeed what I have with the vacuum unplugged. When I hook up the vacuum advance (with the new carter YF carb) is when it goes up to 50 deg. Again, this carb only has one vacuum port so I know I'm using the correct one.  I really can't go the route of adjusting the distributor before the carb as I  have a worn out 1100 on there right now that does not give any advance at all.
See my other thread "Vacuum advance tuning" where Mustang Six made an interesting comment "You may well have 50 degrees of total advance at no-load, high rpm operation (initial+mechanical+vacuum) such as coasting, but the vacuum advance will retard under load" this confuses me a bit as a recent article I saw on checking total advance said that it should be  no more than about 35 deg total, but with all advance including vacuum (or I thought so). I have to go back and check that again....
Thor
